spl setup rca's dont matter //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif but if it was an sq vehicle yes id get differ onesnot 'sure' if you'd get an improvement (more / better signal transfer), but those rcas your useing are bogus, go spend $50 on a good set or 2?
im no scientist or car audio guru, but if you can get more signal / voltage to your amp it'll be louder right?spl setup rca's dont matter //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif but if it was an sq vehicle yes id get differ ones![]()
thats a good idea, ill try it.has enough signal and voltage, that rca cable is used to daisy chain the amp to the other one. I have a better one from the head unit to the first amp but I Tested with a dmm preout of head unit 2.6volts, rca's 2.6volts(both)//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
1 more timesent pm back to ya //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
