Filling gaps for running power wire?
UNDERGROUND_BUM
ok so i have ran my + and - runs of 0 gauge underneath my car and i drilled holes in my trunk floor........ so my question is what do you guys use to fill these holes so water doesn't come in and to protect it from getting cut up and grounding out?
what if i dont have a grommet? i have wire ran through already and it already has been crimped........ do you think "great stuff" alone will do the trick? i did file the edges of the holes so it isnt very sharp at all any more
It would be best to get the edges taken care of, because there's always a chance of the wire moving around and grounding out. Best bet would be to get a grommet, and since the wires are already ran, cut the grommet, open it around the wires, and then put it in. Then shoot it with foam to cover the gaps so no water or anything will get in from the underside.
you should of done some research first and bought the grommet. when doing something like this it will pay in the end to do it the right way. just buy the grommet.
I buy these off parts express. The other advantage with these is they'll also clamp the wire in place to prevent it from moving.
I didn't realize Srim linked the same item as me.
x2!
If I were you I'd cut the crimp to pull the wire back through the trunk with the grommet. Crimps aren't that expensive. Possibly cutting your wire and grounding out = possible massive costs.
UNDERGROUND_BUM
UNDERGROUND_BUM
HAWAII
boomzilla
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
