Fiberglassing....
It depends what kind of finish you're going for. Some take more time than others. I'm not disagreeing with you. It's not necessarily a fast process. It could take 10 minutes or it could take hours or even days depending on the specifics.
few videos i did to show the steps of glassing door pods...
Rage makes some really good products for glassing, look them up for your resin/short/long stand, as well as filler... Biggest thing you want to remember is to use very light layers built up on top of each other, as if you go too heavy you can develop air pockets, which can destroy the integruity of the fiberglass. Fleece works really well for your initial shaping. hope that helps
I agree, if you are sanding to wrap or use a textured paint then there is not much to it. If you are going for show finish then you will have some time in sanding.
brushes?? like paint brushes? and what size work best? i want a fiberglass enclosure that i can paint and will look okay. won't be a super fancy shape. prbly a flat back and bottom then a slanted/ rounded front where the tweeter will be so it will point in-between my seats.
The smaller the piece, the smaller the brushes. For tweeter pods, maybe 3/4" brushes or something like that. Get like 10 brushes. Get the cheapest bristle brushes you can find. You can't use foam brushes with resin, FYI. It will melt the foam.
Just basic paint brushes.... like 50 to 99 cents each...
1/2 inch brushes for small **** and 2 inch brushes for big projects....
Are you trying to do something like this?
Did this to my door. Tweeters cam move in any direction
Why would you need absurd strength for a tweeter pod?
you can use a tshirt material , stretch over the wood piece that you have, soak it in, do a single layer of mat and be done with it.
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
