Fiberglass resin
I was wondering what stores i could go to to find this stuff. And how much does it go for?
Local marine shop................. i would say between 15 to 35 for a gallon wide range but different types and different prices from shop to shop
You can also find it at Hardware stores, auto parts stores, Walmart, Home Depot, Lowes..yada, yada, yada. Boat repair stores are usually the cheapest. Allthough I buy alot of resin from Autozone here is goes for $17.99 a gallon. Walmart is $19 a gallon. Boat shop is $14.50. But that's Virginia //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
is that stuff able to be used for spaces up to 1/2 in. and still stay air tight?
I would use silicon to fill gaps that wide. The resin would seal it airtight. But with that wide of a gap. The vibrations may break the resin. Because it's pretty brittle by itself. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
LuNaTiC
18 to make up for below.
LuNaTiC
MA
ramos
    May 12, 2024
Brendon Jenness
    May 11, 2024
