Fi SSD Question
I think you'd be better off with a different sub. The FI SSD subs like the 800-1000 range.
Yeah, that's what I thought. Do you have any other suggestions other than the RL-P? I hear the RL-P doesn't handle double bass (I listen to a mix of hard rock/rap) to well, so I'm second guessing on buying one. I'm limited to a Dual 2 ohm woofer since I have to wire down to 1ohm on my amp. The sub will be in 2.3ft^3 enclosure tuned to 30Hz.
The only sub I can think of, off the top of my head for that range of power is this one:
http://www.ascendantaudio.com/assassin12specs.html
I'm not really sure how it'd perform for what you want, though.
Could always give this one a try
https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154592fc0c2bbbe/shopdata/0040_X/product_overview.shopscript
I've never heard of anyone buying one of those, so if you did go with it, give us a review //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Problem is I'm limited to one that can wire down to 1 Ohm. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Could shoot Scott an email and see if he'll build you a dual 2.
Scott@ficaraudio.com
Sorry for not helping you at all so far lol. I'll let someone else try to help you out here.
Lol, don't worry you've gave me plenty of help. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif If all else fails I'll just give the RL-P a shot.
you only get 400w at 1 ohm from your amp?
Yea, I'm running it off the rear channels of a Orion 800.4. :/
EDIT: I think I'm just going to give the RL-P a shot. If it isn't responsive enough in my ported I'll switch to sealed. Thanks for all the help guys.
I'm pretty sure it's 1 Ohm (I can verify if I can find my manual). I'm running my IDQ on there wired down to 1 Ohm and it runs perfectly.
Mystify.
Mystify.
KY
champaned_out
Mike Mccabe
