Fi Q
What's Ohm? I see you can select Dual 1 or 2 on the Ficaraudio website but I have no idea what it is or what it means.
And what about this BP Power? Is that worth the extra $40? What does it mean/do?
I say not at this point. May be some in the future, no sure. Right now I believe one would be hard pressed to match it at its price point.
I would say we would need a little more info first, as I was sarcastic before. But the Q is pretty nice.
I would say Mag is probably a little nicer //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Which ohm load your amp is stable to will answer your question on which coil configuration you want to get.
The BP option increases the overall power handling of the sub. There are detailed despcriptions of what each option does on Fi's web site.
Ascendant Audio Havoc 15 is a mean looking sub as well, They're $20 more than a bp'd Q and are supposed to have a stronger motor. The company is run by the same group of guys as well.
If you were to port your type R's like they are meant to be, and run the correct amount of power to them. The R's would be louder.
But sealed, w/o the right power, the R's could easily be quieter than the 15 Q.
The Q would have much more sq though.
newyork2050
newyork2050
ny
newyork2050
vegang
vegang
