a 3inch coil with shorting rings should give it good cooling abilities for a daily driver. Unless you competing honestly the amount of power alot of ppl throw on these drivers is a waste unless they are constantly playing near tuning. At a certain point all drivers start to really suffer power compression anyway so it's sorta moot point. I'd bet they could handle 2k no real issue, probably upwards of 2500 if you werent' stupid with your volume knob. If you want to make sure your loud for daily driving tune relatively low 28-32 and make sure the port is big to avoid compression. If you have good airspace and power the rest should come pretty easy. It may not meter super well, but it will shake things and get pretty loud over a very large bandwith while sounding good doing it. If you didn't like you AQ I don't see the BTL in a similar alignment being any different.How much whats could i throw at an xcon and be safe?
if only there was a loaded xcon lol!!!
