Fi Bl 10"
BL10
DUAL 1 | DUAL 2
Fs: 37.1 Hz | 37.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 4.62 | 4.62
Qes: .23 | .23
Qts: .22 | .22
Mms: 191g | 191g
Cms: 0.96mm/N | 0.96mm/N
Sd: 310cm^2 | 310cm^2
Vas: 13.0 l | 13.0 l
Spl: 86.2dB 1W/1m | 86.2dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1500W * | 1500W *
Sealed box: N/A cuft | N/A cuft
Ported box: .7-1.5cuft | .7-1.5cuft
Sub OD: 11.000” | 11.000”
Cut ID: 9.250” | 9.250”
Mounting depth: 6.250” | 6.250”
Displacement: 0.16cuft | 0.16cuft
Welcome to CA.COM!! I hope you find all you need while you get to know people. There are several enclosure designers here that will get you an enclosure calculated for a small fee and then there are others that could probably help you understand the physics of enclosure calculations and maybe you will be able to design an enclosure yourself!. Either way, you should be able to achieve what you are looking for!
BL10
DUAL 1 | DUAL 2
Qms: 4.62 | 4.62
Qes: .23 | .23
Qts: .22 | .22
Mms: 191g | 191g
Xmax: 18mm | 18mm
wrong section. but your new so its expected. like NT said, if you like your music to play low, go to 32 hertz, if you are looking for straight loud SPL, tune it to like 40, and if you want a good mix go with 35. now these are very general numbers so dont think you have to tune it to one of those three.
BL10
DUAL 1 | DUAL 2
Qms: 4.62 | 4.62
Qes: .23 | .23
Qts: .22 | .22
Mms: 191g | 191g
Xmax: 18mm | 18mm
wow were can i get that done and how much will it range around $
im not the person to ask that lol ive never had it done before. but all i can tell you is to ask around different car audio shops where you live and they may have one that you could rent out. someone on here might even let you use theirs if you live close enough to them
masked 187
masked 187
tucson,az
Falcons
BP1Fanatic
BP1Fanatic
