Fi 12" Which ones??
528hz
Everything'sMiscellaneous
Well this will be my first use of Fi subs. I'm going to be running an IA 20.1 and
want to run 2 12" Fi's in a sealed box. I have been suggested SSDs, BLs and Qs. I
am coming from an SI Mag 15" and loved the way it sounded at 2.5 sealed, but I
could use a little bit more bump. I would like to run the IA to it's full potential (
1800x1 @ 1 ohm) so for SQ and SPL which should I choose between the 3?
Go with 2 SSDs. The other two are rated at 1000watts so you would be "underpowering" them (although I'm sure the 20.1 does more than 1800)
I don't think you will be disappointed with the SSDs
528hz
528hz
In the Space between Space in NM
revrider1
