sikcavy
i plan on doing mostly the floor and deck lid.. possibly doors.. which do you guys recommend?
what makes SS damp any better than fatmat? from what both their sites say fatmat and damplifier are the same thickness......Neither, fatmat is nothing more than peel and seal with a blue logo on it and should never be used in a car.
Edead is just not a good product in any way.
Go for second skin
Secondskinaudio.com
Is this Rudy just swaying yet another guy or what?Because fatmat is asphalt based and should not be used in a vehicle, on top of that is mass loading properties are terrible compared to almost any other deadener. Thickness is not everything.
So using SS you will have to use FAR less to achieve the same results, and you dont have to worry about it failing due to heat and or its poor adhesion ability.
Edead suffers from inconsistency, I regrettably installed some edead in one of my vehicles. The mylar backing (which is a terrible substitute for a foil backing) peeled off the "butyl"
raammat is a good deadener, if your on a budget that is what I would suggest.If you cannot go wrong with second skin.
i have used both in my car and both are still holdin fine. doin a couple layers of fatmat today on my roof. and its going on 2+ yearsNeither, fatmat is nothing more than peel and seal with a blue logo on it and should never be used in a car.
There is some stuff called "Goof-off" from the makers of goo gone, it will dissolve it instantly.how would you go about prepping? i have some nashua 357 spray adhesive that i need to get off my decklid before i can apply this.. you guys got any ideas on how to get this off?? goo-gone takes literally all day.
I would love to use SS but the fact is if I can get my truck completely covered with the cheap stuff, as apposed to some of it with SS. and its a little less sound proof o well.Out of any mat I've used Second Skin is my favorite product //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif On a budget go with Raamat, IMO.
That doens't make sense.I would love to use SS but the fact is if I can get my truck completely covered with the cheap stuff, as apposed to some of it with SS. and its a little less sound proof o well.
Sweet fancy Moses you are an idiot. Do you ever go back and actually read what you type? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifIs this Rudy just swaying yet another guy or what?
I will recommend fatmat.........have had it in my car going on 2 years now with no problems what so ever. Have it on my doors, floors and rear quarters, the rest is secondskin damp. Seems to be holding up just as well as the damp and I have the fatmat in the areas in my rear quarter where it rattles the most and it has helped a ton.
Also have you used fatmat before or peel and seel? Or just playing the broken record of what Rudy says?
For the money, I see nothing wrong with it and I would buy more. I don't care what Rudy or the other guru's say, it has worked in my case. I have yet to really come across any deadener that don't do the trick and I have used many from expensive to inexpensive. Only bought the secondskin due to the reviews and honestly can't tell a dam difference. It was eaiser to install is all I can think of, but did slice my hands up pretty good.
I am sure most will go against the post, but I don't care. I have done plenty of deadening isntalls and have not had one fail on any brand I have used and all have helped quiet down the rattles, which is what they were looking for.
I guess if you have the money, do secondskin......or Cascasde, if not nothing wrong with fatmat......just make sure you do the prep and install it right and it will work. These people that have had bad luck, just don't prep and install it the right way IMO.
