factory unit.
I like FI
ive read that you can avoid using loc. by splicing rca into hu output wires.
my bose system uses external amp, so i believe i can use signal between hu and amp. i will measure how high it is.
my question is, rca has 2 wires in it, does it mater which is - and +? anycase the outside wire is -? and inside is +?
i had done that on my factory Toyota gear. I did have some ground thump when switching radio modes, but it was fairly minor. Some models (of Toyota radios) use a digital connection between the HU and amp, so this is not possible. I don't know is your bose is like that.
generally ground is the outside and positive in the inside just as you stated.
I like FI
I like FI
miami
Babs
