SimulatedZero
I have a 2005 Nissan Pathfinder. I pulled the door panels last night to start sketching out designs for sheet metal plugs for the inner panel and I found out that my car already has some dampening on the outer panel. Relatively smart dampening too.
There are two horizontal braces running the length of the door, one at the bottom and one halfway up. The one at the bottom is a 1 inch pipe welded to the the outer skin every 2 inches and the upper one is a standard I brace design. In between the upper and lower brace there is a 6"x12" sheet of some dampener slapped right in the middle of the space. About 25% coverage. The space above the upper brace is completely covered in one layer of that same stuff.
It looks factory to me, so the question is, would it really be worth it to either pull the existing sheets off and redo it or just add new material on top?
My goal here is to increase midbass out of my 6.5 more than reduce outside noise. I'm still going to seal the inner panel with sheet metal and run a layer of dampening on each side to reduce resonance. Do I really need to touch that outer skin, or is it good?
