Factory Radio removal in cavalier
  • 6
Yup.
It's really easy...
Screw/Bolts in:
Top middle vent, side panels of both sides, gold heads in glove box. Slide top of dash off, take out remaining screws holding dash bezel on, replace radio, replace parts.
Take me about 15 minutes to do a a new deck install...
nG
Thanks much
The screw is inside the vent?
Im not looking at the car now, just want a heads up for the install.
Like, there's a plastic cover and a screw holds it in, it's like the defrost vent. Take the molding off, then there is also a screw underneath after you take it off.
There's mass screws.... just and //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I've probably done 50 of these...
nG
Never understood why they made it to where you have to take off the dash to get to it. Fawking ghey!
Easy if you done...........50 of them, but a pain in the arese if it is your first time. I hated doing deck installs in the cavy's.
My Focus is so simple. Get a plastic flathead, pop the trim piece and take out 4 bolts. Bingo, bango, lol!
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
587
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Cameron_B
Single Cab Loud
Cameron_B
NC
Brian_smith06
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
