Sold F/S USAMPS MD3D 2000W RMS @1ohm
ampjunkielikeme
275.00 shipped to the cont usa... firm...no trades..
the amp works great!... ive been using it for about a week in my room on my 12's.. the amp is solid. it will put out its rated power with no problem. it has a power supply from hell..//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
i rebuilt the output section of the amp... it has all brand new date code matching parts.plus all the other parts needed to make the amp more reliable for the long run...
vibration upgrades have been done to the amp also.. added solder to the "fets" legs.. epoxy the transformers, capacitors, and other parts that tend to break off the board.....it is better now, then when it was first made...
cosmetics are a 8 out of 10 .. it has scuffs and scratches..comes with a plexi bottom instead of a metal one...
10 out of a 10 for function... it works flawlessly.
i will give you a 30 day warranty on the parts i installed....
MD3D - US Amps 1 Ch Amplifier MD 3D
650W rms x 1 @ 4Ohm mono
1200W rms x 1 @ 2Ohm mono
2000W rms x 1 @ 1Ohm mono
* Total Harmonic Distortion: 0.03%
* Frequency Response: 20~250
* Power Band Width (Frequency Response): 20~500 Hz
* Crossover Frequency: 40~250 Hz - 15~40 dB
* Damping Factor: 100
* Dimensions: 2.5 x 10.5 x 21.75 Inches
* Fuse Rating: 40A x 6
* Power Voltage Range: 12~16V
* High efficiency Class D design(1D/2D/3D)
* Output stages utilize high-current MOSFET devices
* High speed, audio-grade components in all low-level stages
* Active Constant Current Bias Tracking Circuit
* Platinum-plated RCA inputs and connectors
* Wide range of sensitivity accepts signal from any head unit
* 24dB/octave Subsonic Crossover
* 24dB/octave Lowpass Crossover
* True Line Output
* Auto Bridge feature
* Short Circuit Protection
the amp will not be doa... it has been tested to work as it should...i would not sell it , if it did not work 100%
this amp has the 6 40 amp fuses.. 3 inside. 3 outside..
i need the cash right now..thanks for the offer...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ampjunkielikeme
ampjunkielikeme
nash, tn
ampjunkielikeme
