Sold F/S Sundown 3000D, 50.4 and 15" Nightshade
RetroAudioinc
Custom Car Audio Decals
1. Product:
Sundown Nightshade 15" D2
2. Specs:
If you want a loud subwoofer to use both daily and in the SPL lanes then look no further than the Sundown Audio Nightshade. Many Sundown Audio customers are already using Nightshade woofers to achieve SPL levels in excess of 150 dB on music in their vehicles! *
The Nightshades feature strong paper composite cones with an additional stiffening disc located behind the thick poly dust caps. The tinsel leads are tied down to the spiders so you never have to worry about the leads slapping or popping against the cone and spider at high excursion levels!
The Nightshade woofers are assembled in the USA with only the best high strength adhesives and materials.
* Please use caution as excessive SPL levels such as those achievable with the Nightshade subwoofer can cause permanent hearing damage!
  • Dual 2-ohm or Dual 1-ohm Voice Coils Available
  • 3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
  • High Temperature Aluminum Voice Coil Former
  • 1500-Watts RMS Power Handling
  • Over 2 inches peak to peak excursion
  • Wide, triple-layer foam surrounds for high excursion
  • Extremely strong paper cones w/ stiffening disc
  • Thick poly dust caps
  • Cast Aluminum 12-spoke basket with cooling vents
  • Triple Stacked 1" x 9" magnet slugs for high motor strength
  • MSRP - $629 USD
T/S D2 **:
RMS: 1500
Z: 4 ?
Re: 2.92 ?
Fs: 41 Hz
Qms: 9.36
Qes: 0.46
Qts: 0.44
VAS: 11.7 L
BL: 22.8 NA
3. Description/Condition:
Used, I got it on this site from allout13. never had an issue with it, was in 3.5 cube box built by spy, sounds great off my 3000D it will take 3000wrms all day I never had a single issue only did one comp with it.
4. Price: :
$375 shipped
5. Pictures:
that nightshade is the one and only subwoofer I ever regret selling //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifglws, man
I am in no rush to sell it to be honest.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Sounded great in my truck and my car..
3000 old heat sink in great shape, never over heated never had an issue at at all with it, never repaired or anything.
The 15" nightshade was in my Truck a chevy 2500HD 4 door for a little bit and then it was in my 1996 thunderbird in the trunk and it sounded great on the 3000D.
The 2 of them go great together. 3.5 cubes tuned to 36hz in my car sounded great.
you have a pic of it in the 2500hd? I have the same truck wanna see how that box would look in the back seat. GLWS
What back seat.. lol I took out my 2/3's of the back seat and made a floor. At first I just had it seating in the seat. It worked but did not look the best. I don't know if I have any photos of it in there as it was only in there for about a month until I moved it to my car. I can show you what my setup looks like right now.
Does sundown do repairs on their amps?
I'd be runnin that amp at 1 ohm for a dd9512g. I'm assuming it'd be comprable to the nightshade, but ive never heard one in person
DB-R fixes all the sundown amps for sundown.
The 9512G is a bit more SPL then the nightshade, the nightshade will be more musical then the DD. I also have 2 DD9515f's
I also have the org box for the 3000D and the bass knob. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I can ship the same day if paid by 2pm. Will ship USPS or UPS what ever is cheaper, insured and tracked.
These amps are underrated no? Is there a birthsheet or anything?
No they don't have birth sheets but as all sundown stuff it's very under rated. At 14.4v you should see about 3400wrms at 16v you would see close to 4000wrms.
These are solid amps you can't really go wrong with sundown.
Lol and I def can't pick it up from that zip code
Oh pack a few sandwiches and some soda's it's not that far from Rhode Island to Orlando.. haha
BTW the $550 price is shipped, insured and tracked. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
