f/s Rockford t600-2
select127
Rockford Fosgate T600-2
Ok condition, there are scratches and scuffs but the amp performs 100%.
Power Series Compact 2-Channel Amplifier
RMS Power Output:
4 ohms: 200 watts x 2 channels
2 ohms: 300 watts x 2 channels
Bridged, 4 ohms: 600 watts x 1 channels
CEA-2006 compliant
Dynamic Thermal Management cooling system
Differential Input circuitry eliminates hum
Variable high- and low-pass filters (50-500 Hz, 24 dB/octave)
Variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
Optional remote bass/treble boost
Class AB amplifier design
MOSFET power and output stages
Preamp inputs and outputs
4-gauge power and ground leads and a 150-amp fuse recommended — wiring and hardware not included with amplifier
No on-board fuses — when installing multiple amps in a system, an additional 150-amp in-line fuse between the distribution block and the amplifier is recommended
Frequency Response: 20 Hz - 20 kHz
Dimensions: 9-5/8"L x 13-11/16"W x 2-3/16"H
$170 shipped
NO TRADES PLEASE
select127
select127
Florida
select127
