1. Product:
for sale an re audio sx 15 d4 sub in perfect condition.
2. Specs:
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
Electrical Q Value -Qes: .38
Mechanical Q Value -Qms: 4.7
Total Speaker Q Value -Qts: .38
Free Air Resonance -Fs: 27.8 Hz
Equivalent Compliance -Vas: 126.3 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency - SPL 1W/1m: 90.4 dB SPL
Effective Piston Area -Sd: 810 cm^2
DC Resistance -Re: 1.9 ohm
Mounting Depth - 7.75”
Mounting Hole Diameter - 14”
Overall Diameter - 15.5”
Bolt Hole Circle - 14.75”
Motor Width - 6.5”
Motor Depth - 3.25”
Basket Depth - 4.5”
Displacement - .18 cu. ft.
Weight - 27 lbs.
Dual Composite 2-piece Cone
Rubbertek Foam Surround
Cast Aluminum Basket
Tork-Tite Terminal
3 " 8-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Triple Stack Maganets
Progressive Spiders
Wrap around Rubber Gasket
3. Description/Condition:
its used but in good condition
4. Price: :looking for 235 shipped or a trade for some sundown sa 12's d4's
5. Pictures:
2. Specs:
Motor Width - 6.5”
Motor Depth - 3.25”
Basket Depth - 4.5”
Weight - 27 lbs.
Tork-Tite Terminal
Progressive Spiders
5. Pictures:
