PIONEER GM-5100T 2-CHANNEL AMP
Used, with a few scuffs and scratches on the exterior, but GREAT working condition.
Cosmetically-7/10
Mechanically-10/10
Power source ................................................................ 14.4 V DC (10.8 — 15.1 V allowable)
Grounding system ........................................................................................ Negative type
Current consumption ......................................................... 30.0 A (at continuous power, 4 Ω)
Average current drawn* .......................................................... 10.0 A (4 Ω for two channels)
19.0 A (4 Ω for one channel)
Fuse................................................................................................................. 30 A × 2
Dimensions ......................................................................... 300 (W) × 60 (H) × 327 (D) mm
[12 in. (W) × 2-3/8 in. (H) × 1ft. 1 in. (D)]
Weight ......................................................... 4.7 kg (10.0 lbs.) (Leads for wiring not included)
Maximum power output .................................................. 250 W × 2 ( 4 Ω) / 760 W × 1 ( 4 Ω)
Continuous power output ....................... 125 W × 2 (at 14.4 V, 4 Ω, 20 Hz — 20 kHz 0.2% THD)
380 W × 1 (at 14.4 V, 4 Ω, 20 Hz — 20 kHz 0.8% THD)
190 W × 2 (at 14.4 V, 2 Ω, 20 Hz — 20 kHz 0.8% THD)
Load impedance ............................................................................. 4 Ω (2 — 8 Ω allowable)
(Bridge connection: 4 — 8 Ω allowable)
Frequency response ............................................................... 10 Hz — 50 kHz (+0 dB, –1 dB)
Signal-to-noise ratio ......................................................................... 95 dB (IHF-A network)
Distortion ....................................................................................... 0.015 % (10 W, 1 kHz)
Separation .................................................................................................. 70 dB (1 kHz)
Low pass filter .............................................................................. Cut off frequency: 80 Hz
Cut off slope: –12 dB/oct
Bass boost ............................................................................................. Frequency: 50 Hz
Level: 0/6/12 dB
Gain control ...................................................................................... RCA: 200 mV — 6.5 V
Speaker: 0.8 — 26 V
Maximum input level / impedance ............................................................. RCA: 6.5 V / 22 kΩ
Speaker: 26 V / 40 kΩ
$70+shipping OBO
Lower 48 states only
View attachment 26537897View attachment 26537898View attachment 26537899
Cosmetically-7/10
Mechanically-10/10
Level: 0/6/12 dB
Speaker: 0.8 — 26 V
$70+shipping OBO
