Well i just got finished unintalling everything out of my car......Time to invest into a new hobby....golf //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
1. Oz Audio Matrix Elite 10 ($100 + actual shipping)
I had this sub installed in my car for about 8 months and it performed nicely.....had it in a .75 cubic foot sealed box and fed it approx. 500 watts from the MMATS amp.....it is 9.5 out of 10 cosmetically and 10/10 mechanically....I will also include a 4 bar grill i bought from parts express...you can see it in the pics.
Specs:
Diameter: 10"
Impedance: Dual 4 Ohm
Power Handling (RMS/Peak): 700W / 1400W
Sensitivity (1W/1M): 85dB
Frequency Response: 20-500Hz
Xmax (mm): 25mm
Fs (Hz): 36Hz
Mounting Depth: 6 1/2"
Mounting Diameter: 9 1/8"
Voice Coil Diameter: 2"
2. Oz audio Matric Elite 130CS 5.25's ($150 + actual shipping)
I had these installed in my car for approx. 8 months power by only a 250a2 (70 watts per side)....these things we babied and are in freat condition.....the tweets have a little bit of glue on the side of the but tat will be gone before you get them. They are 8.5 cosmetically and 10 mechanically.....these are the best 5.25's I have ever heard.....they are very high end and retail for over $300
Specifications OZ-130 (woofer)
Cone Material: Mineral-filled Polypropylene
Voice Coil Diameter: 1" (25mm)
Magnet Weight: 16oz
Fs: 93 Hz
Qms: 4.321
Qes: 0.920
Qts: 0.759
Re: 4.0 Ohm
VAS: 0040 M3/.141 ft3
Specifications OZ-25 (tweet)
Cone Material: Coated Silk/Cotton
Magnet Weight: 0.43oz
Sensitivity: 90db
Frequency Response: 1,000Hz - 20,000Hz
RMS/Peak Power: 50/100
Fs: 1100 Hz
Qms: 10.251
Qes: 0.5376
Qts: 0.51
Re: 4.0 Ohm
3. MMATS D700.2 ($150+ actual shipping)
The amp is the same at the D700.1 but it put out full power at 2 ohms instead of 1 ohm. I bought this amp off of ebay looking for something to power the ME10....it was hard to find an amp to push the power i wanted @ 2ohms for the ME 10 but this fit the bill perfectly....It is in great shape with no mark that I can tell.....it is a beautiful amp in that glossy black color.....going by most MMATS amps i would guess this amp puts out about 850 watts @ 2ohms. It also has a very small foot print for the amount of power it puts out....MADE IN THE USA...can't beat that....comes with origional box
Specs:
700 W RMS 2 Ohm Mono
Leading edge technology
Efficiencies over 90%
4 AWG battery inputs
Optimized for low impedance loads
Dual MOSFET power supplies in the HC models
24db low pass Linkwitz-Riley infinitely variable filter
Frequency Response(-3db) 10Hz to 230Hz
Signal to Noise Ratio -92db A weighted
Distortion@Rated Output
Damping Factor@100Hz >125
Input Sensitivity 150mV to 2.5Vrms
Idle Current 1 amp
Efficiency @ 1/3 power >72%
I am not accepting trades
Paypal address and email is MrMorganUSC@yahoo.com
I have REFS on SIN and here.....ebay name is MValley70
Ask me if you have questions
Scott, SC
Specs:
Diameter: 10"
Xmax (mm): 25mm
Fs (Hz): 36Hz
Magnet Weight: 16oz
Fs: 93 Hz
Qms: 4.321
Qes: 0.920
Qts: 0.759
Re: 4.0 Ohm
Sensitivity: 90db
Fs: 1100 Hz
Qms: 10.251
Qes: 0.5376
Qts: 0.51
Re: 4.0 Ohm
Specs:
Idle Current 1 amp
Scott, SC
