I have a set of MB Quart QSD216. Just traded an amp for them with a member on CA.com. they work perfectly fine and sound pretty amazing, they come with the origional box and all mounting hardware. Honestly i just dont feel like dealing with building baffles and deadening doors to get full potential out of them. im at work and will have pics of them this evening. These are on ebay right now for $800, but can be yours for $300 shipped!! hit me up with any questions. Pics up shortly
SPECS:
*Q-Series QSD 6-1/2" Component System
*Midrange with 37mm (1.5") voice coil is used - Former made of Kapton foil (a temperature resistant plastic) that can withstand extreme heat
*25 mm (1") Titanium Dome tweeters with a highly elastic butyl rubber surround
*Balanced Temperature Technology is used throughout
*Tweeter level can be adjusted in 2dB steps up to -6dB
*Built-in light bulb on the crossover networks to extend the life of the tweeter using overload protection
*Ability to upgrade the midbass with the Add-A-Woofer-System
*MB Quart easy speaker connections. Connection types include solder, screw-down, spade or bare wire
*Designed specifically for low-profile installations. The diecast aluminum baskets can be installed in most factory locations with little or no modification. They are lightweight and extremely rigid
*A new variation of the WPC process used in QSD is applied in the QSC component system
Design: 2-Way Component
RMS Power Handling: 80 - 150 watts
Sensitivity: 90 dB
Frequency Response: 35 - 32.000 Hz
Impedance (per voice coil): 4 ohms
Top Mount Depth: 2.5"
Cutout Dimensions: 6.61"
the pics:
SPECS:
Sensitivity: 90 dB
the pics:
