Jla Audio 300/4 Slash Series Amplifier
GENERAL SPECIFICATIONS:
Recommended Fuse Value: 40A
Recommended Fuse Type: AGU or MaxiFuse™
INPUT SECTIONS:
No. of Inputs: Two Stereo Pairs (Front, Rear)
Input Type: Differential-balanced with RCA jack inputs
Input Range: Switchable from 200mV - 2V RMS
to 800mV - 8V RMS
AMPLIFIER SECTIONS:
Amplifier Topology: Class AB with patented Absolute
Symmetry™ dual N-Channel MOSFET output design
Power Supply: Independent, pulse width modulationregulated switching power supply with multistage
impedance optimizing circuitry.
Rated Power (Stereo):
75W RMS x 4 @ 1.5-4Ω (11V - 14.5V)
Rated Power (Bridged):
150W RMS x 2 @ 3-8Ω (11V - 14.5V)
THD at Rated Power:
(20 Hz-20 kHz)
Signal to Noise Ratio: >108.5 dB referred to rated power
(A-weighted, 20 Hz-20 kHz noise bandwidth)
Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
Damping Factor: >200 @ 4Ω per ch. / 50 Hz, >100 @ 2Ω
per ch. / 50 Hz
Slew Rate: ± 25V/µs
FILTER SECTIONS:
Front and Rear Filters (2): State-variable, 12 dB/octave
Butterworth or 24 dB/octave Linkwitz-Riley low-pass or
high-pass with continuously variable cutoff frequency from
50 - 500 Hz, switchable to a range of 500 - 5000 Hz, via
x10 switch. Defeatable.
DIMENSIONS (LxWxH):
13.4" x 9.25" x 2.36" (340mm x 235mm x 60mm
Asking $150 + Shipping O.B.O
INPUT SECTIONS:
to 800mV - 8V RMS
AMPLIFIER SECTIONS:
THD at Rated Power:
(20 Hz-20 kHz)
per ch. / 50 Hz
Slew Rate: ± 25V/µs
FILTER SECTIONS:
DIMENSIONS (LxWxH):
