345.00 shipped to the cont usa..........no trades
ive had this amp for a while now, but its time to move on to bigger and better amps...its worked great for me....and it will work great for you to....
on looks i would give it a 8 out of a 10. it has a couple scuffs and scratches, but nothing major.......on functionality, i would give it a 10 out of a 10. it works perfectly
does 1000 watt regardless of the ohm load from 1.5 to 4 ohms.....this is the only amp i know of that can do this.....its built like a tank . and is ready to pound some subs...
Specifications:
* Rated Power: 1000 watts RMS at 1.5 ohm - 4 ohms (at 11V-14.5V)
* THD at RMS Power:
* S/N Ratio: >95dB below rated power
* Frequency Response: 5Hz - 500 Hz
* Damping Factor: >500 at 4 ohms /50Hz
* Input Range switchable from 200mV-2V RMS
to 800mV-8V RMS
* Dimensions: 19.7"L x 9.25"W x 2.36"H
* 1 pair of Differential-Balanced Inputs
* Fully variable on-board crossover: (40Hz - 200Hz), selectable-slope LP (12 or 24 dB per octave)
* 2-channel Preamp Outputs: independent active filter, parallel with amp filter or full-range
* Bass EQ that is parametric with variable bass boost up to 15dB and you can use a Remote Bass Control (optional RBC-1)
* Fully variable Infrasonic Filter: 24dB/octave from 15-60Hz
* Output Polarity Reversal switch allows instant output polarity reversal
* Dual mono speaker output connections that accepts up to 8 gauge wire
* 12 volt and Ground connections accept 4 gauge wire or 2 gauge or 1/0 gauge
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.......it has been tested , and works 100% ...
Specifications:
* THD at RMS Power:
to 800mV-8V RMS
