Sold F/S Garage Clean out Old skool Amps/ RE Subs/ Selenium/ Wiring
dye4metal
Prices will be OBO, im pretty flexible dont LOWBALL ME //content.invisioncic.com/y282845/emoticons/pissed.gif.9f665f96bc89e98e708dabd4580bb591.gif
All prices are WITH OUT SHIPPING
i can try to do flat rate boxes but for the threads sake i cant charge the same for another FL resident vs Cali. If you want any more pictures be my guest and ask me.
if you want to speak to me on the phone about anything my number is 941-8zero7-5eight4two
Hifonics Olmypus XI- $300
Condition-7/10 Front is Good back is scratched and Labels on side for adjusts are slightly faded
Mechanical-10/10 ive bridged it and ran it 4 channels works perfect and is underrated for sure //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
4 x 125 Watt @ 4 ohms
4 x 200 Watt @ 2 ohms
4 x 250 Watt @ 1 ohm
2 x 400 Watt @ 4 ohms bridge
2 x 500 Watt @ 2 ohms bridge
Fuse: 80A
Hifonics Bxi 2006D-$225
Condition-9/10 very few scuffs looks worse in pictures from hand prints all over it
Mechanical-10/10 works perfect
1 x 650W @ 4 ohm
1 x 1300W @ 2 ohm
1 x 2000W @ 1 ohm
Some Bazooka Amp-$30
All i know is that it works and is how u see it in the picture
Power Acoustik A3000DB-$120
Condtion-9/10 Great looking amp is and is huge
Mechanical-1/10 Doesnt work friend brought it to me blown, im almost sure its the mosfets on the side i got a picture of. seems like a easy fix. i would do it my self but no time in college and no use for it.
1 x 1100W @ 4 ohms
1 x 1800W @ 2 ohms
1 x 2300W @ 1 ohm
PPI PC450-$130
Condition- 6/10 Not bad for being made in 1998 and still looks decently good
Mechanical-10/10 ive gone through all filters and bridging works flawless and is definitely underrated:crazy:
4 x 50W RMS at 4 ohms
4 x 100W RMS at 2 ohms
2 x 200W RMS at 4 ohms bridge
Fuse: 60A
Manufactured in 1997-1998
(4) RE SR 10s dual 2s-$300
Condtion- 10/10 look awesome
Mechanical-10/10 bought these off of the member Brian Owens shop owner and i never used them. Coils read perfect. These are underrated and can take a CLEAN 400-500 watts all day
RMS-300watts
(Yes i know only 3 are in pics) one was upstairs
(4) Selenium ST350 Super Tweeters-$125
Condition-10/10 They are Brand new still in the selenium box
Mechanical-10/10 anyone who knows selenium know these things are LOUD
*Power handling: 75 watts RMS/150 watts program (above 5,000 Hz)
(6) Selenium 6W4P 6" Woofer-$150
Condition-10/10 They are brand new also
Mechanical-10/10 are rated for 100w RMS but take way more
*Power handling: 100 watts RMS/200 watts max *VCdia: 1.25" *Le: 0.57 mH *Nominal impedance: 8 ohms
**WIRING**
Tape measure in picture is at 12ft.
1/0 gauge
KnuKoncepts KLM cca wire---- BLUE TO THE LEFT
2 Runs one with 200 amp fuse holder
1-about 13-14ft------------$30
2-13-14ft with fuse holder------$50
Phoenix Gold 1/0 OFC (clear jacket)
1 run about 25+ft(i can measure exact if interested)-SOLD
Tsunami Competition 1/0 AWG OFC Blue jacket
1 run to the far left about 16-18ft-SOLD
Big 3 Setup with KnuKoncepts battery Terminals-SOLD
Brand New KnuKoncepts 3/2 Distro Block with 60,80,150 fuses-$15
I also have a bunch more speaker wire and 4 and 8ga. PM if you want any.
**RCAs**
3 sets
1-Kicker 4 channel RCAs-Make offer
1-Knukonceptz (Nicest ones they have)-$30
1-No Name work fine-$5
i have an out look monitor for the bully dog tripple dog, a diablo sport pressure box, leveling kit. some other misc. stuff. ill have to take a look when i get home.
hey man....i got a chance to hook up the battery terminals and do the big 3 kit...the most obvious is the battery + to alternator...thats done
with that short run on the ground...where did you do battery - to the chassis on your tahoe?
i am lacking the chassis to engine block connection, some trick to make it all work with what i bought from you cuz im not seeing it...i would need about 2-3 feet to go from chassis to engine block from what i can see
lemmie know when u get a chance! thanks
on the tahoe what i did. there is a bar that goes across the top of the battery. scrape the paint off of the one end and put the terminal in between the bar and body. and the other ground goes the bolt on the alternator. back a bolt out of all the way and put the terminal on the bolt that holds the alternator on and thats a ground block. the whole alt body is a ground block so any bolt on it is a ground.
oh ok...cool....i see it now...did you have any problems with that ground spot between the bar and fender?
that bolt you are talkin about on the alternator...will that back out without the alternator getting all loose and the serpentine belt slipping off?
yeah i got 2 runs left of the knukonceptz
and yeah u can take it out without the belt falling off. even if the belt does fall off put a 1/4" ratchet wrench in the idler pulley and un tension it. lol those belts are about as easy as it gets to get off and on
dye4metal
dye4metal
Tampa, Fl
dye4metal
