1. Product:
RD Audio 7500.1
2. Specs:
Features
* Digital class-D linkable mono block amplifier
* MOSFET PWM power supply
* Daisy-chain through output RCA
* Heavy duty cooper layer double sided epoxy PCB
* Stable into 1 ohm and 2 ohm parallel amplifier connection availability
* 24 dB low pass (LPF) crossover variable
* 18 dB bass boost equalization control variable
* 180 degree variable adjustable phase shift
* 24 dB subsonic filter variable
* Selectable Switch for MASTER and SLAVE Operation
* Speaker short, over current, thermal, and DC protection circuit
* RCA line input and line output
* 2 x 0 guage (AWG) battery input connectors
* Efficiency: 86% at 4 ohm, 100 Hz
* Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
* Operating voltage: DC 10V ~ 18V power input
* Damping factor: better 350 into 1 ohm
* Wired remote controller
MSRP
$2899.00
Specifications
RMS power, .875 ohms mono 7500w X 1CH
RMS power, 1 ohm mono 6000w X 1CH
RMS power, 2 ohm mono 3000w X 1CH
RMS power, 4 ohm mono 1500w X 1CH
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 600A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 870(L)mm
3. Description/Condition:
It has broken mosfets and needs to be reboarded. The amp is already at RD Audio waiting for the new owner to pay for the board which will cost a flat 300 dollars. Pretty cheap for a HUGE POWERHOUSE amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I dont have time to deal with the amp, and I am going a different direction with power.
The amp does not have a backplate, which I am owed from RD Audio. We can work something out on that.
8/10 Cosmetics
4. What you are looking for: :
Anything really.... if it spikes my interest we can talk. NO LOWBALLS! This amp is very expensive to buy outright.
5. Pictures of your item for trade:
** DO NOT DELETE ANYTHING BELOW THIS LINE OR THREAD WILL BE DELETED **
This message is automatically inserted in all classified threads.
Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
1) Telephone number. Call the number back at a unspecified time and make sure that it is the person's correct phone number.
2) Name and address including postal code
3) Valid e-mail address. Send an e-mail requesting a response to information about the deal being made.
DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
If transaction was completed on CACO, please use iTrader to record feedback.
Potential traders should check iTrader feedback also before continuing transaction.
RD Audio 7500.1
2. Specs:
Features
MSRP
$2899.00
Specifications
T.H.D @ 4 ohm
8/10 Cosmetics
