Sold F/S: Eclipse 8053 + RF Amp, Coaxials, Screen
squeak12
Eclipse 8053 + Rockford Fosgate 3002
Amp does 75x2@4 and 150x2@2. It looks a little rough, but it works 100% fine.
Eclipse is active ready and dead head, but that is what the amp is for. I only have the HU, Cage, and harness. NO remote or manual. I can get more specs on the HU if needed. I can include plenty of 8 gauge wire for the amp wiring. You will just need RCAs and remote wire. I might even have speaker wire too.
225 shipped with 8 gauge power and ground
Polk Audio DB651 6.5" Coaxial
Dynamic Balance polymer/mica composite woofer with butyl rubber surround
3/4" pivoting liquid-cooled silk/polymer composite dome tweeter
Neodymium tweeter magnet
Kapton voice coil
ABS wheel-design grilles
Certified for marine use
60 watts RMS
Sensitivity: 92 dB
top-mount depth: 1-11/16"
I still have the original box, grilles, manual, and a set of screws that it came with.
75 shipped
Concept 9.2" Widescreen monitor
* Screen Size 9.2"
* Aspect Ratio 16:9
* Panel Type active matrix TFT LCD
* Resolution 800 R.G.B x 480
* Resolution Dots 384,000
* Pixels 1,152,000
* Brightness 400 cd/m2
* Signal Format System NTSC / PAL
Power Properties
* Power Source DC +12V +/- 15%
* Power Consumption ~ 500mA
* Operating Temperature 32°F ~ 140°F
* Storage Temperature 14°F ~ 158°F
* Operating Humidity
Physical Properties
* Unit Dimensions (W x H x D) 10" x 5-3/4" x 1-1/4"
* Unit Weight 2 lbs
105 shipped
I will consider offers, but they aren't too negotiable.
squeak12
squeak12
Thomaston, GA
squeak12
