Sold F/S Diamond Audio 800.1 Mono Amp & 2 D12D6 Subs! Great Buy & Cheap
Ankit69
Recently Bought [ About 3 months ago ]
These are 2 Diamond Audio D6's Subs, along with a diamond MONO block 800.1 amp
The specs on the amp are
Amp
~ 4/2/1 ohm stable
~ 800 watts x 1 at 1 ohm
~ 610 watts at 2 ohms
~ frequency response 20-20khz.
~ signal to noise ratio >100db.
~ THD .05%
~ input sensitivity 250mv.-5v.
~ high level input sensitivity 500mv.-5v.
~ Power supply operating range 10.8-15.6 volts
~ Dimensions 2 1/4" H x 8 1/2" W x 12" L
~ Variable high and low pass filters
~ variable bass boost
~ Wired remote sub bass control knob included
~ remote turn on with soft start
~ PWM mosfet power supply
~ Low AM RFI and auto protection circuits
~ Gold plated input / slave output terminals / RCA ports
~ Aluminum heat sink for efficient heat dispursion
~ Low profile / compact size for limited space installs
~ Crossover mode switching
~ 1 channel usable for multiple applications
SUBS
2 Diamond D6's - 12"
These are the specs :
~Frequency Response: 22-250Hz
~Efficiency: 85.5dB
~Impedance: Dual 2 Ohm
~RMS Power Handling: 600 Watts
~Peak Power Handling: 1200 Watts
~Mounting Depth: 6.2 Inch
~Mounting Diameter: 12 Inch
~Size : 12 Inch
THESE ARE VERY POWERFUL SUBS!
These two subs are mounted in a custom box for a 6th gen maxima which will be included in the final price,
Prices are as following:
2 - 12" - D6's Subs $330
1- 800.1 - Amp $195
Box - $115
These prices are shipped
Everything together will be $580 Shipped... This system retails over $1400 and i payed $1200 to get them professional installed!
Open to offers...
sorry bro just joined today, promise everything will go smoothly... im a member at caraudioforums.com but then heard about this place... payment can be made anyway you are comfortable
Ankit69
Ankit69
New Jersey
Ankit69
