First up: Diamond D1 250.2
# RMS Power @ 4 Ohm: 250 Watts x 1
# RMS Power @ 2 Ohm: 125 Watts x 2
# RMS Power @ 4 Ohm: 75 Watts x 2
# Class AB Amplifier Topology
# Bridgeable Output Capability (4 Ohms)
# Stereo/Mono Mix Capability (Hybrid 3rd channel from 2 channels)
# Stable into 2 Ohm Stereo Loads
# Internal 12dB/Octave High Pass or Low Pass Filter (40-400Hz)
# Pass -Thru Line Output for Daisy Chaining Amplifiers
# Versatile for either full range or subwoofers
# Pulse Width Modulated (PWM) MOSFET Switching Power Supply
# Extruded Aluminum Heatsink
# Nickel Plated RCA Low Level Audio Inputs
# Nickel plated, low resistance power and speaker connector blocks
# Power ON and Protection LED Lighting for Easy Diagnostics
# Thermal, Short Circuit, and Overload (Low Impedance) Protection
# 6dB bass boost
# Chassis mounted ATC/ATO type automotive fuses
# Crossover Switchable (Off/HP/LP)
# Dimensions: 9.0" L x 8.6" W x 2.25" H
Condition Cosmetically 9.9/10 and Mechanically 10/10
Second Up MTX Thunder 4202:
Power 14.4 VDC
2 Ohm Load 140 w x 2
4 Ohm Load 85 w x 2
Bridged 4 Ohm Load 280 w
Dimensions
(with ISO Feet)
9.3" x 9.75" x 2.1"
23.6cm x 24.8cm x 5.3cm
Pics upon Interest
Shape Cosmetically 8/10 (few very light scratches on "chrome")
Starting @ 80 + shipping each. Or 100 shipped. (whichever is cheaper for you)
Prices very negotiable. Need these gone //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
# 6dB bass boost
Power 14.4 VDC
4 Ohm Load 85 w x 2
Dimensions
(with ISO Feet)
9.3" x 9.75" x 2.1"
Pics upon Interest
