Sold F/S 100.00 Lunar L60x2 made in USA! 240W RMS
ampjunkielikeme
i couldn't edit my old listing so i made a new one....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
L60x2 100.00 shipped!( to the cont usa)
I have a very rare lunar l60x2 amp. it is in good condition ,(check the pics)
it works 100% and puts out the best sound ive ever heard from such a small footprint......very low distortion.....produces music loud and clear...
if you haven't tried lunar out yet, i recommend you do A.S.A.P.
this one is way cheaper that buying one new...these amps can get very expensive!
• High power series made in the U.S.A. !
• Class A/B
• 4 Ohm Stereo= 60 watts rms x 2
• 2 Ohm Stereo= 120 watts rms x 2
• 4 Ohm Mono= 240 watts rms x 1
• 2 Ohm Mono= Not Recommended
• Over Current Shut Down
• Over Temperature Shut Down
• Left and Right Gain Controls
• Recommended Fuse-- 35 amp
• Heat sensitive fan cooled
• a nine segment average output indicator
• Distortion @ rated power-- .015% @ rated power
• Signal to noise ratio ->100 unweighted
• Frequency response- 9hz-30khz
• Regulated power supply- 9.5 - 17 volts
• Fan cooling-- all amps
• Heat sensitive fan control
• onboard crossover-- 12db per/oct. high pass /full range /low pass
Dimensions: L60x2- 3.5" x 10" x 6.5"
can't believe this hasn't sold yet. g/l with the sale, and i'm still watching this hoping i can pick it up myself when i get the money (or if you get desperate and keep lowering the price low enough for my broke as_s).
i will take it. email if you would since I dont check the site as often as i used to. This would look great with my L60x2, L1500, and L250HC.
solaceravr at excite dot com
I can paypal or send mo.
ampjunkielikeme
ampjunkielikeme
nash, tn
subfrontier
