Extremely Loud Popping
I pulled the HU out, ran a pair directly to the amp, still pops when windows lowered.
RCA plugged into HU and disconnected from Amp = No Popping when Passenger Window is raised/lowered.
RCA disconnected from HU and plugged into Amp = No Popping when Passenger Window is raised/lowered.
So does this imply the only other reason is a faulty ground ?
I will try a new ground for the HU in the meantime.
I grounded the HU to a small screw hole on the very back of the HU itself.
I used to multi meter and it tested as a valid ground point.
I also grounded the RCA wires to this same ground point.
The prior ground point tested as a valid ground point aswell.
It still pops when the window is lowered/raised
What would be the next suggestion?
Just wanted to take a moment to thank everyone for helping me through this.
Probem: Sheared off speaker wire inside door panel (hidden) near window mechanism, was touching metal.
Solution: After ripping it out with a great deal of force, I ran some new wires in a different location.
It now plays fine, NO MORE POPPING !
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
crazyone
crazyone
Canada
crazyone
