Explain Volts and Ohms
you should focus on purchasing one aspect of your setup, and then after match up the remaining pieces of it to what you have. If you have anything currently let us know and we can direct you from there.
voltage is the work required to move a charge (electrical property of atmoic particles) from point A to point B
impedance is a measure that describes the opposition of a sinusoidal wave, ohm's is the unit attached to it.
im pretty sure we will end up doing it. last yr in freaking intro IPC(integrated phys. and chem) we did series and parallel circuits. im a sophomore btw
Y'all might do it, but you won't really understand much of it without knowing how to differentiate or integrate functions.
SLrocket
SLrocket
the SL, tx
maldecido33
Mike Mccabe
