Experienced Users
xtully
Hey everyone //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was wondering if anyone had experience with Autotek M4000.1D, It is very low priced. I'm looking for an amp that can do 2000rms at 1 ohm.. low thd and high efficiency at 1 ohm
Also : Hifonics HFi2500D, Hifonics BRZ2400.1D, Hifonics HFi3000D, Soundstream RUB1.2500D
Then don't look into either of those amps.
Okay, lets switch this up a little bit. I would like to match amps since I have a front stage comp set rated at 150 rms ( polk audio db 6501). So which companies offer a mono amp listed above and precision and a/b class amp that has detailed external settings? Onyx, cadence, and dd? Any others?
* sundown also does, but they are a bit out of my price range currently
of what you listed i would go with the rubicon2500 or the brz, pref. the rubicon though.
why do you want a class a/b? class d's are designed for sub setups and perform best that way.
A/B class to power my front stage comp set.. polk audio 6.5" 150wrms
I would like to match amps thats why I'm making it relevant. I mine as well go for aq2200d if I was considering rubicon2500, right? But still I need an accurate and precise a/b comp amp with detailed externals.
^ 4th post in this thread bro haha
oh lulz
quart would be a solid setup but they only make a 1500 @ 1 amp. DD and sundown would also be a good choice but they cost loads
I guess im stock with Jl audio now..//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I guess there is still cadence, Ill have to check what the offer for 2-channel. Which is their best line zrs, flash. exenith, or united?
if your wanting pure efficiency then take a look at mmats. pick up the M2000.1 and one of their 2 4 chan offerings
that said those arnt going to be cheap.
I want good clean sound, so yes efficiency is important component. haha and quick esitmate on the cost of combo?
xtully
xtully
Akron, Ohio
Phoenix Risen
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
