Experienced Users
xtully
Hey everyone //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was wondering if anyone had experience with Autotek M4000.1D, It is very low priced. I'm looking for an amp that can do 2000rms at 1 ohm.. low thd and high efficiency at 1 ohm
Also : Hifonics HFi2500D, Hifonics BRZ2400.1D, Hifonics HFi3000D, Soundstream RUB1.2500D
Then don't look into either of those amps.
Okay, lets switch this up a little bit. I would like to match amps since I have a front stage comp set rated at 150 rms ( polk audio db 6501). So which companies offer a mono amp listed above and precision and a/b class amp that has detailed external settings? Onyx, cadence, and dd? Any others?
* sundown also does, but they are a bit out of my price range currently
of what you listed i would go with the rubicon2500 or the brz, pref. the rubicon though.
why do you want a class a/b? class d's are designed for sub setups and perform best that way.
A/B class to power my front stage comp set.. polk audio 6.5" 150wrms
I would like to match amps thats why I'm making it relevant. I mine as well go for aq2200d if I was considering rubicon2500, right? But still I need an accurate and precise a/b comp amp with detailed externals.
^ 4th post in this thread bro haha
oh lulz
quart would be a solid setup but they only make a 1500 @ 1 amp. DD and sundown would also be a good choice but they cost loads
I guess im stock with Jl audio now..//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I guess there is still cadence, Ill have to check what the offer for 2-channel. Which is their best line zrs, flash. exenith, or united?
if your wanting pure efficiency then take a look at mmats. pick up the M2000.1 and one of their 2 4 chan offerings
that said those arnt going to be cheap.
I want good clean sound, so yes efficiency is important component. haha and quick esitmate on the cost of combo?
xtully
xtully
Akron, Ohio
Phoenix Risen
