everything hooked up right, but no power to the amp
im runnin a kicker cvr 15 with a kicker ix405d amp bridged, i had it hooked up sloppy, then took it all out, carpeted the box and cleaned up all the loose wires and now am getting no power to the amp. Have terminals on the 12v ground and rem, all the fuses are good as is the ground. Any ideas??//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
I second test wires with a DMM, and check for missing fues's. Also, check to make sure your fuse is still good, with the DMM. I had one that looked good but was slightly broken could not see the crack in it without looking under a microscope. Took me a day to figure that one out.
yeah all fuses are good, none missing checked em all. the amp light doesnt turn on at all i onno wtf is up, shit was workin 30 mins before i took it out. The only shit that happened in that time was wen i re-ran the rem line and touched the chasis n poped a lil 10amp fuse, n replaced it, other than that, i just pulled the shit out n put it back in
fried the remote out from the deck maybe. jump the amp power to remote terminal and see if it powers up. Then get a test light and test from remote out off deck and see if it lights up when you turn on car. I bet you fired the deck rem output
x2
oneightseven
oneightseven
los angeles
audiophile26
