EQ Question
  • Thread starter atwistd1
  • Replies 0
  • Views 396
atwistd1
I am installing my new Arc Audio PEQ 7 and have a question, on the back of the unit, there is a set of input connectors and an aux in connector, and 2 sets of out (front and rear). My HU (Eclipse AV8022) has front and rear out plus a sub out. I do not use the rear out as i do not have a rear stage. Should i keep my sub out from the Eclipse brain directly to my sub amp and my front out into the Arc piece or as recommended by the local Arc dealer run the front from the brain into the PEQ 7 and come out of the PEQ with the front out going to the front amp and the rear out going to the sub amps. there is a fader control on the PEQ but i think i would have better control of the sub by going directly from the Eclipse brain to the Sub amps and only using the PEQ on my front stage controlling my EDi's. Any suggestions or is the arc dealer correct and run everything off the PEQ?
atwistd1
atwistd1
New York, NY
atwistd1
