Enough power for a jl 12w3v3-4?
comp2007
Im adding 1 12" jl 12w3, will an alpine mrp m500 have enough power so the sub is not underpowered? I can just get the 4 ohm JL and run it at 2ohm and get 500 rms correct?
Stats:
Mono subwoofer car amplifier
300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
Variable low-pass filter (50-200 Hz, 24 dB/octave)
Variable bass boost (0-12 dB at 50 Hz)
Subsonic filter (15 Hz, 24 dB/octave)
Class D amp with MOSFET power supply
CEA-2006 compliant
STAR Topology (minimizes internal noise and prevents ground interference)
Speaker- and preamp-level inputs
Gold-plated screw terminals
Fuse rating: 30A x 2
8-gauge power and ground leads recommended wiring and hardware not included with amplifier
10-6/8"W x 2-1/2"H x 9-5/8"D
If its a single 2 ohm voice coil then yes. Id go with dual though, because you may change things out over time or add another one so your options will be greater with the different wiring ability's. But its also easier to go with a single voice coil.
Ok do you think the type R would fit in my box?
12" subwoofer with dual 2-ohm voice coils
Kevlar® reinforced pulp cone with Santoprene™ rubber surround
cast aluminum frame with perimeter venting
frequency response: 23-500 Hz
power handling: 200-500 watts RMS (250 watts per coil)
peak power: 1,500 watts
sensitivity: 85 dB
top-mount depth: 7-5/8"
sealed box volume: 0.57-1.0 cu. ft.
ported box volume: 0.75-2.0 cu. ft.
Box specs:
It is 8.25 inches deep, 11 1/8 inches around cutout and 1.2 cubic feet.
would the type r be too close to the back of the box?
comp2007
comp2007
Phoenix,AZ
comp2007
