Engine Wine GONE!!! :D:D:D:D:D:D:D
MmatsDude
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I had no idea this would take it away. I have 2 batterys installed(front and rear) and I am running negative wire from batt to batt. Couple of minutes ago I desided to ground the rear battery in the trunk for the hell of it just to get a more solid ground eventhough my rear battery is grounded to the front battery. So I ground the rear battery to the chassis in the trunk(battery still grounded to the front battery too) and the engine wine went away, I dont hear it on the speakers no more.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp: Also I notice that whenever I close the hood I get a voltage increase by .4, I think the hood is providing more ground?
It's possible that the the hood is pushing up against the ground and providing more of a surface area.
OR MAYBE UR ENGINE ADDZ DBZ?!?!?!?
Where do you have your power & ground wires ran? Could have maybe cut a wire if you ran it threw the firewall.
I made a hole through the fire wall. Both the positive and negative running through together. I check'd there too, and both were fine. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
MmatsDude
MmatsDude
Los Angeles CA
MmatsDude
