Engine whine
Wiked RuffRyder
im starting to get engine whine from my speakers, i never had this problem before, i just started to hear it now and it pretty loud, i also hear a poping noise when i changed the station, changed songs, switch radio to cd. someone told me that it that my battery is getting weak, can a weak battery cause this?
Check all grounds, if possible, connect all ground wires to one point. If all grounds are solid, try using an "ground loop isolator." I had a loud alt wine, checked all grounds (and it is solid), then I put a ground loop isolator, front and rear, and the noise is reduced to bearly audible. It is enough for me, I don't plan on entering any sound competion.
Hope this helps
Wiked RuffRyder
Wiked RuffRyder
Yay Area
da12b
BP1Fanatic
BP1Fanatic
