Engine Whine/Hissing Noise
kingsnake2009
Hello,
Here are the symptoms of my problem. If i turn the ignition to ACC the unit starts as normal but i get alot of excess noise out of the tweeters. If i unplug the RCA connectors at the back of the hu, the noise disappears. If i was to turn the engine on, i get a loud alternator whine through all speakers and i can hear about every electric motor in the car over the speakers.
Here is what i have done to remedy the problem. First off I have a 90 Corvette that is mostly fiberglass, so i ran a 4 gauge ground wire straight from the amps to the battery. I ran a 14 GA solid wire from the hu to the battery, I grounded the shielding of the RCA's to the same wire as well as the deck chassis. I tried putting filter caps on the battery and acc connections- Made noise worse. Tried running a 14 ga ground and power wires straight from my amps to the hu- no change. I took 4 ga jumper cables and tried clamping them from the battery ground to the frame and engine block- no change Changed amplifier out- same noise. Tried a different Deck- noise gone. If you have any suggestions to hepl me track this down it would be much appreciated. I am running a Rockford Punch 600a4, Punch 1000a2, Rockford 10 Farad Hybrid cap, 2 10" Cerwin Vega V-MAX Subs, Pioneer TS-C720PRS's and TS-C520PRS's, Stock alternator, and an Optima Red Top.
Thanks
P.S. Just tried tearing the car apart and replanning RCA cable runs. Went down and bought Monster Cable RCA's and here's what i have now. If i set the cables outside the car and connect to the amp input I get some noise. If i disconnect i get very very little noise (acceptable amount). If i lay those cables through the car and connect to the hu... I start to get more noise even before the connector connects to the pre-amp out of my deck, like within an inch or two. Then i get alot of noise with the RCA connected. What am i missing here?! I took my brand new deck apart and fixed the blown fuse to no avail. Is there more to this Pioneer noise thing than just the RCA ground?
here you go bro.http://www.caraudio.com/forum/search.php?searchid=5901535&pp=30&page=2..I had the pigtails so just find a way to groung your rca jacks ...good luck homie
kingsnake2009
kingsnake2009
Boise, ID
FOSGATE JOE
