Engine Noise?
plyer3
When my headunit is turned off, I can hear the engine noise on my mids when I press on the gas pedal. Not sure if it's coming from the mids, but I know it's coming from somewhere in the front.
My ground wires are grounded under the backseat. Both 4-channel and mono amps are grounded to the same place. The noise doesn't really bother me when the headunit is on, but it does when it's off.
i have the same problem and my amps are grounded at the battery and the back battery is grounded to the front battery and the front battery is grounded in stock location, although i have cheap rca's and they are by the power wire and i am using a loc that might be my problem
however yours might be if the rcas are by the power wire
if the amp is off then it cant be from rcas... might have exposed speaker wire. or the terminals on the speaker could be to close to metal... not really sure. try putting electrical tape on the speaker terminals.
plyer3
plyer3
N Little Rock, AR
Linkz
