Engine noise through RCA's ( NOT PIONEER)
WashYourWinky
The Pilot
I have engine noise through my RCA's. Sub amp only. The hu in question is a Alpine CDA-7894.
I have tried different RCA's, different ground locations for the hu including straight to the battery. Also grounded the antenna. I would try to ground the rca's but they are set up different than the Pioneer units, and I don't know how to ground this type.
Its not my amp the sound stops when I unplug the rca's.
I'm starting to think the hu is going bad.
I'm sure I have missed something, what do you guys think?
Set it to continuity.
Start with the amp and put one probe on the ground terminal and then touch the outer part of the RCA connectors with the RCA's unplugged. If it beeps then you're good. If not, then that's not good.
Do the same to the cd player. One probe on the chassis of the CD player and the other to the outer part of the rca connectors. If it doesn't beep, you'll have to get it fixed.
Awesome! Digging out the DMM right now.
The grounds in the CD player are probably the cause. It could be the amp though. I had an amp in my truck that was doing that. It had a busted trace. I can fix the headunit or the amp if you need me to.
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
xNaStYx
