EL_Weenies New Amp
infamous_e46
hArRy_DaNgLeRs
wit mallard standing on it
specs nao
# Soundstream D-Tower Series Monoblock Class D Car Amplifier
# RMS Power Rating:
* 1 ohm: 2200 watts x 1 chan.
* 0.5 ohm: 3400 watts x 1 chan.
# Full MOSFET Power Supply
# The worlds first vertical automotive stereo amplifier
# Double side PCB and SMD components
# LED power (green) and protect (red) indicators
# Monoblock operation
# Gloss black finish w/ brushed accents
# Dash mounted remote gain control
# 3-Way System Protection circuitry (thermal, short, impedance)
# Heavy duty aluminum alloy heatsink for extreme heat dissipation
# Nickel-plated RCA level inputs
# Nickel-plated screw terminals
# Variable high-pass filter (10-50 Hz)
# Variable low-pass filter (40-220 Hz)
# Subsonic Filter (10-50 Hz)
# Bass boost frequency: 30-90 Hz
# Bass boost level: 0-12 dB
# Signal-to-noise ratio: >85 dB
# THD (Total Harmonic Distortion): 0.5%
# Damping factor: >200
# Frequency response: 10-220 Hz
# Dimensions: 17-3/4"L x 3-5/16"W x 7-1/2"H
# 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased toget
# Soundstream D-Tower Series Monoblock Class D Car Amplifier# RMS Power Rating:
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
