Steven Kephart
The woven tinsel leads is actually a bad thing. It causes wear spots on the spider that reduces the subs life.Originally posted by ElementalG20 The brahma vs the 12a.22. I am FAR from being the most educated in terms of woofer design, and technology, but there are a few facts I tend to hang onto. The XBL2 motor is a benefit, I wont take that away, the idea, and technology is a break through, in more ways than I know, but probably not in to many ways i can personally hear. I've heard both the brahma and the 12a.22's. Both are excellent woofers, but the build quality of the 12a.22 IMO exceeds that of the brahma, woven leads, and over all better fit and finish, and according to eD, the variance between woofers is kept to a very tight tolerance that there previous builder wasnt able to reach(to my knowledge eD's former buildhouse is the current buildhouse for the brahma) if they cant do it for eD, kind of wonder if they can do it for adire(QC/variance issues).
The Brahma's don't have a tinsel lead slap problem anymore. My B10 sit's only a couple feet away from my head under my dash inverse mounted. If anyone would be able to hear lead slap, it would be me with my setup.Originally posted by ElementalG20 Just curious, how good does a low distortion woofer sound, that STILL has lead slap issues? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Yup, its an easy fix, but shouldnt be needed to be fixed on a woofer that is already more expensive than the eD woofer. As far as the comparison to the EVO-R, yes they drivers are very similiar, however the new flat cone, among other changes have allowed the 12a.22 to do things the evo-r was not capable of.
So, what performance differences does the ED A have over the EVO-R? In fact the EVO-R used a progressive spider rather than dual linear spiders. This means their Kms curve is better than the A.
I explained this in my other post. The cone hits the spider platform on this type of basket design in 31mm. Their tier puts it up 9mm. 31-9 is 22mm. I got this information directly from Dan Wiggins, who was playing with a 12A. He said it physically can't move backward more than 22mm.Originally posted by ElementalG20 Also, why would that spacer used to allow a 2nd platform for spider mounting suddenly reduce rearward travel? The spiders still have ample travel, and in the 12a's case lock down doesnt occur until the cone is nearly touching the top tiere spider, 15a is however motor limited do the the greater distance between the cone/spider mounting posititon.
