Sold Eclipse SW9152Pro Titanium subwoofer by TC Sounds
kramster
This sub is SOLD, the sub has been tested and each coil reads ~1.7ohms or the equivalent of a quad 2 ohm. I am looking to get $300 plus shipping.
For sale one 15" Eclipse SW9152Pro titanium subwoofer made my TC Sounds for Eclipse. Thise retailed at around $1900 was was a earlier version of the LMS.
Size 15˝
Fs 27Hz
Qts 0.15
DCR 2Ω/coil (quad 2 ohm)
Vas 2.0CuFt
Xmax 3.5˝ peak-to-peak (max: 4˝)
• Triple-stacked magnet
• Sealed box enclosure recommended
• Continuous power handling: 3,000W
• Music power handling: 5,000W
• Quad voice coils
• 350oz. magnet motor
• 4˝ diameter voice coils
Features
• Premium foam surround
• Titanium cone
• Asymmetrically mirrored spiders
• Aluminum voice coil former
• FEA-CAD designed
• Aero-vented pole piece
• Proprietary diecast aluminum frame
(patented large excursion, high dissipation frame)
PLEASE note the sub is in PERFECT working condition but one of the wire terminals has been damaged. The buyer will either have to repair the terminal or can direct solder to the connection as the easiest method. See pictures
excellent sub. i bought it thinking it was a quad 1 but we found out it was not. Chances are we'll ship it out from my place to save some money. Sub in excellent condition.
as far as the terminal goes....you can easily get to the leads and crimp your 8awg speaker wire driectly to the tensile. If you go to home depot they sell a large pack of these copper crimps for like 7 or 8 bucks. You really only need 2 but these a single crimp could fit a 4awg wire (just the copper). After you crimp you can then ziptie each wire to the basket through the hole from where the the terminal used to go through. Really all you need are a small crimper, 2 of these cheap copper crimps or comparable, and 2 zip ties and you have a fully functional $1600 retail sub for 300+ ship. I've used 4hp's and a few ti pro tops before and this is a STEAL of a price. I'd keep it if didnt envolve getting a new amp to play 2 ohms or .5ohm, I'm sticking with 1 ohm for my setup.
someone buy this!
kramster
kramster
Houston, Tx
kramster
