eclipse ea4200, dsc15001.d
perfecxionX
1. Product:
Eclipse ea4200, 4channel class d full range
2. Specs:
4-channel car amplifier
60 watts RMS x 4 at 4 ohms (70 watts RMS x 4 at 2 ohms)
140 watts RMS x 2 bridged output at 4 ohms
CEA-2006 compliant
variable high- and low-pass filter (30-500 Hz, 18 dB/octave)
variable bass boost (0-8 dB at 45 Hz)
subsonic filter (18 Hz, 18 dB/octave)
two sets of preamp-level inputs, one set of preamp outs
full-range Class-D amplifier design
MOSFET power supply
fuse rating: 30A x 1
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
10-1/4"W x 2-3/8"H x 7-11/16"D
3. Description/Condition:
theres 1 or 2 small scratches on it, id say 9.5/10 cosmetically, 10/10 functionally
One of the low-high filter switch ends snapped off, it still works, but you need to use a small screwdriver (or something) to switch it(easy). I included a photo of this
4. Price: :
80 shipped to CON US
5. Pictures:
1. Product:
mbquart dsc1500.1d
2. Specs:
Discus Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 375 watts x 1 chan.
2 ohms: 750 watts x 1 chan.
1 ohm: 1500 watts x 1 chan.
PWM (Pulse Width Modulated) MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-9 dB bass boost at 45 Hz)
Soft start sound
Preamp RCA outputs
DC, short, thermal, and overload protection circuitry
Unbalanced RCA inputs
Damping Factor: >180
Variable input level control: 0.2V-0.6V
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (15-35 Hz)
Frequency response: 15-250 Hz
Dimensions: 14.17"L x 9.45"W x 2.7H
few scratches on the cover, id say 8/10 cosmetically, but works perfectly, im the original owner, have all the original packaging/etc, and took good care of it as i do all my stuff
4. Price: :
140 shipped to CON US
5. Pictures:
perfecxionX
perfecxionX
indianapolis
perfecxionX
