Eclipse EA3532 5 channel amp. SQ!
Drich79
As the title states.
Works great! Could use a little cleaning. Has a couple scuffs.
Specs:
Very under rated!
* 105W x 4 channel Max. Power Output at 2 ohms plus 230W x 1 Max. Sub-Out
* 60W x 4 channel (2 ohms), 120W x 1 channel (4 ohms), 0.1% THD Stereo @13.8V (RMS Continuous Power)
* 40W x 4 channel (4 ohms), 120W x 1 channel(4 ohms), 0.1% THD Stereo @13.8V (RMS Continuous Power)
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
* Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
* High-Level Input – Add on Capability
* Epoxy Composite PCB
* 2 Ohm Stable Design
$60 + Shipping.
These are great amps. Very under rated. In a side by side comparison with an Eclipse XA5000 (rated 420@2 on the sub channel), the 3532 was louder on the same sub setup and gain matched with a DMM.
Drich79
Drich79
Omaha
Drich79
