Eclipse 88150 aluminum enclosure help
  • 4
UMWDawg92
Missoula, MT
So I'll be getting an eclipse 88150DVC aluminum in a couple days and I've been working on designing the enclosure for it. The t/s specs have been hard to find but this is what I've found:
Qts .39
Qms 5.00
Qes .423
Vas 6.1 cu feet
Fs 27hz
Re 3.0
I've noticed eclipse does not recommend porting this sub but when I run it in WinISD it models very nice and flat in a low tuned ported box, I'm getting that 4.5-5 cubes net tuned to 27-28hz looks really good. I'm going for SQ over output. So what do you guys think? Does that seem about right? Oh and what kind of port area should I use?
From what I recall, these do very well in overly large enclosures for the type of output that you desire.
If youre interested in having a professional design done, let me know and we can accomidate your needs.
Good luck with your build.
ok thanks, it models really flat in a large ported box. I am considering have a design done so I may hit you up for a quote.
Anyone else have thoughts?
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
918
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
UMWDawg92
UMWDawg92
Missoula, MT
UMWDawg92
