Eclipse 8053 & Zapco
brypink
I did a search and I read this entire thread (it confused me):
http://forums.caraudio.com/vb/showthread.php?t=95543&highlight=eclipse+cd8053
Now, my questions is simple (I hope)...How to run balanced connections from my 8053 (which already are balanced) with my Zapco amps (which accepts balanced)? Do I still need to utilize Symbilink? If so, how?
HU-8053
Amps- (2) Zapco 350.2s (front & rear) & (1) Viper d2500.1 (sub)
Comps-(2) pair 6.5 Utopias (front & rear)
I would consider bi-amping just my fronts with no rears. I'm not sure if I would know how to set it up properly.
I am pretty sure all you have to do is convert the balanced rcas to the 6 pin mini din connector of the amp's input. You should not have to use either the BLA or the symbilink.
Thanks for the input. Is there an adapter/connector for this? RCA to 6 pin cable?
Anyone else know?
brypink
brypink
Temecula, CA
3.5Max6spd
