Eclipse 5 ch amp - 5/4 mode question
Hi there, wondering if someone can help me. I read an ad from someone a while ago on ebay about a 5 channel Eclipse amp, a 3650 or 3532 or something that was a 5/4 amp that had a switch for 5 or 4 channel mode. They said that if you run it in 4 channel mode, the front 2 channels get more power.
So, instead of 2 x 40w front, 2 x 40w rear, and 140w x 1 sub (5 channel), you'd get 110w x 2 front and 40w x 2 rear (4 ch).
Can anyone please confirm or deny that an Eclipse 5 channel amp with 5/4 mode sends more power to the front channel when in 4 ch mode? Only documentation I've found is the same eclipse catalogue over and over on the internet that gives specs, but not other info (not user manual).
Thanks!
Thanks ya, the 3532. I found those specs in the catalogue too, but there's no mention of what 4 channel mode means. They only give specs for 5 channel - 40x4 + 120X1 @ 4ohm. Looking for info on the 4 channel mode thanks - does your manual talk about running the 3532 in 4 channel mode?
Tyler
Tbonem3
Tbonem3
LA, CA
Tbonem3
