Ebay
@Warden: Thanks man, you've been helpful. I searched those subs on here, and didnt find any. How much do you figure I can find some for?
Honestly, find yourself a nice single Type R used (can probably be had for ~$75) one type R with the right power would be louder than both those setups you posted. Then get yourself a nice little 500w amp (probably another $75) and build your own box (maybe another $30 or so in materials).
Type R is a very good choice too, just find the second version, not the newest one... the one before it with the accordian type surround.
Yo dude if you want the best bang for your buck, go with Power Acoustik Mofo 152x, or a P3. Heres a vid on what my p3 did at 680 Rms. Now im upgrading to a Mofo. Dont listen to me on there about 1000 to 1100 rms.
Im cincinnati i can build you a spec'd sealed box for cheap if you want. depends on how far from here though i suppose
Hey thx alot man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'll show you some specs,
10" 12" 15"
Mounting Depth 5.5" 6" 7.5"
Mounting Hole Diameter 9.25" 11" 14"
Motor Width 6.5" 6.5" 6.5"
Weight 18lbs 18.5lbs 19.5lbs
VC Diameter 2.5" 2.5" 2.5"
Magnet Weight 15lbs 15lbs 15lbs
Power Handling RMS/Peak 300/600 300/600 300/600
Impedance D 4ohm D 4ohm D 4ohm
Sd 334.00 cm² 519.00cm² 872.00cm²
Vas 36.40 L 73.90 L 145.10 L
Cms 2.33e-04 m/N 1.96e-04 m/N 1.36e-04 m/N
Mms 93.47 g 131.94 g 168.60 g
Fs 34.1 Hz 31.3 Hz 33.2 Hz
Bl 20.89 20.89 20.89
Re 7.20 ohm 7.20 ohm 7.20 ohm
Qms 4.31 6.68 7.88
Qes 0.49 0.53 0.58
Xmax 18 mm 18 mm 18 mm
Sensitivity 86.5 dB 88.2 dB 91.5 dB
Suggested Sealed .4³ - .6³ ft .55³ - .8³ ft 1.5³ - 2³ ft
Suggested Ported .7³ ft 1.25³ ft 2.5³ ft
Suggested SPL Ported 1³ ft 1.5³ ft 3 ³ ft
Can you ship it? I'll PM you if you can.
brendan127
brendan127
IN
hatedonmostly
