earthquake amps?
thats what i thought myself. i've heard almost nothing about earthquake audio but they have some pretty high end stuff on onlinecarstereo. the price for the amp seemed amazing for that much power so i piqued my curiosity
usually 10 x fuse rating tells you what the amp puts out.these are the lower line earthquake amps ,i would say no.but i can find out ,one of my teammates works for earthquake
would he want to multiply it by 12.8 or 14.4 depending on his voltage...
typically its 70 amps to 1000 watts for a rough gesture, so by the sounds of it, maybe, but thatd be a far stretch.
Amps x voltage x amp. efficiency = Approx. Output
Example= 70 amps x 13.8 volts x 65% efficiency = 579.6 watts. This is only an approx. figure as all three numbers can be affected by various elements. For example, lower ohm loads will usually reduce amplifier efficiency.
Nighthawk1192
Nighthawk1192
Sacramento, CA
Spooney
